Hurst Shifter Sticking
Ok I just bought a 79 Camaro and it has a hurst shift kit in it with the th350. It seems like its harder to use than others I have driven.
Does anyone know if I can grease it or service it in some way to make it smoother
Thanks
Thanks
Yes, you can use some grease inside the mechanism under the box that the shift arm comes through. If you open it up you'll see where the factory greased them and you can see if things are solidified. Clean it up and lube it good.
Pro_built7
11-26-2007 08:48 PM
