how much horsepower can 200r4 take
Old 01-11-2012, 02:53 AM
jason7504's Avatar
i got my 200-4r from extreme automatics and will handle around 700hp and 600-650tq. you can get 200-4r's to handle alot of power but you have more power than i do as i only have around 500-550hp at crank. with your amount of power i'd go with a 4L80 from jake and they can be full manual without controller. you will need to shorten driveshaft and replace crossmember. if you wanna run a mechanical speedo you will also need the mechanical tailhousing for extra $400-500.
  #22
Old 01-11-2012, 12:20 PM
Vall, Jake is one of the true innovators left.
  #23
Old 01-11-2012, 02:01 PM
bad436z28's Avatar
yeah he sure does know his stuff,and those trannies are well worth what he charges alot of work in those trannies,and he takes pride in the work he does that there says alot and he stands behind everything he sells.
  #24
Old 01-11-2012, 06:03 PM
I've heard good things about this company, but didn't see anything on their site about a 4L80E that would make it a 4L80 without a controller? Maybe I missed it when I looked around there. Even their transbrake 4L80E still uses electronics from what I could tell?
  #25
Old 01-11-2012, 09:23 PM
bad436z28's Avatar
if u click the link damon posted it says that half way down the page when the talk about the transbrake for 500 bucks u can get it either with having to use a controller or no controller required.
  #26
Old 01-11-2012, 09:26 PM
bad436z28's Avatar
here it is val from his website.
The new Jake's Performance 4L80E transbrake is here! We have designed an all new transbrake for the 4L80E. It does NOT require a deep pan like our competitor's unit. It can be setup as automatic with computer controlled or can be built as a full manual setup where no controller is required.
  #27
Old 01-11-2012, 09:56 PM
Thanks! I figured I was missing something!
  #28
Old 01-11-2012, 11:57 PM
bad436z28's Avatar
ur welcome,that would probably make a sweet tranny for racing and the street but a little expensive unless i did one myself,then added the transbrake.what u think about the 4L80e val,is that a pretty tough tranny from the factory.like the 400 is,or needs lots of work to handle the power.
  #29
Old 01-12-2012, 11:04 AM
I haven't had much experience with the newer 4L80E. All I know is what I read about them, and it's all good from what I hear. They've been compared equal to the old TH400, with electronics added. But even they aren't cheap in stock form, unless you get a good deal used.
  #30
Old 01-12-2012, 11:31 AM
The subject in this paragraph is the transbrake option, not the trans itself. A transbrake is used for drag racing, in place of putting your foot on the brake pedal. The brake can be set up with a controller to unlock it when the engine hits a certain rpm, or you can have it set up to where you switch it on and off manually. This is what that "computer controlled or full manual" reference is to. I see nothing on that website saying anything about a 4L80 (non-E).
Quick Reply: how much horsepower can 200r4 take
