How much do you think this is worth?
Old May 20, 2009 | 10:37 AM
carralo1's Avatar
Default How much do you think this is worth?
I HAVE A 1981 CAMARO Z28 WITH T-TOPS 81K ON THE BODY BLACK WITH MINT RED INTERIOR. I GOT THIS CAR ABOUT 6 MONTHS AGO FROM MY FRIENDS DAD JOHN SANTILLE AND DONE A LOT TO IT I AM THE THIRD OWNER ON THE CAR THE ORIG OWNER WAS A LADDY FROM BROCKTON MASS THEN WENT TO THE SECOND OWNER WHO RESTORED THE CAR ABOUT 4 YEARS AGO WHO WITCH PUT IT IN HIS COLLECTION JOHN SANTILLE OF THE CADDLIAC CENTER OF BROCKTON MASS WHEN I GOT THE CAR IT WAS CLOSE TO STOCK WITH A ZZ4 MOTOR WITCH I TOOK OUT NOW FOR WHAT HAS BEEN DONE TO THE CAR SINCE I GOT IT WE WILL START FROM FRONT TO BACK CAR HAS A SBC 355 JUST REFRESHENED WITH H BEAM RODS FORGED INTERNALS PETE JACKSON GEAR DRIVE CAM HAS A 580 LIFT CRANE 1.6 ROLLER ROCKERS VICTOR JR INTAKE DEMON 750 CARB RON DAVIS RADITOR ELETRIC FAN WITH ADJUSTABLE TEMP CONTROL BULIT IN POLISHED PULLEYS MSD DIST MSD 6AL MSD BLASTER 2 COIL MOTOR WAS BULIT WITH ALL ARP STUDS HAS CAMEL HUMP HEADS ALL WORKED PORT POLISHED EXCT FULL BIG SHOT NOS KIT BRAND NEW NEVER USED IS INSTALED BUT NOT WIRED UP OVER $900.00 INTO THE KIT WITH PURG TH350 JUST REBULIT WITH ABOUT 100 MILES XTRA CLUTCHS HARDEN SPRAGS AND SHAFTS 3,000 B&M HOLESHOT NITRIOUS STALL CONVERTER SUBFRAME CONECTORS HEADERS 3 INCH EXHAUST WITH XPIPE 2 CHAMBER FLOWMASTER MUFFLERS WITH 3INCH TAILPIPS BEHIND THE TIRES 12GAL FUEL CELL IN THE TRUNK WITH -8 FUEL LINE FROM FRONT TO REAR FRAM FUEL FILTER MOUNTED IN THE REAR UNDER THE CAR YOU CAN SEE IT FROM THE BACK HOLLEY BLUE PUMP CAR HAS HOTCHKIS FRONT LOWERING SPRINGS AND REAR LOWERING LEAF SPRINGS AND FRONT SWAY BAR CAR HAS A 6 INCH COWL HOOD LIFT OFF NOT PAINTED STILL IN GEL COAT SILVER COMP GAUGES TACH OIL AND TEMP MOUNTED UNDER THE COWL HOOD CAR HAS 15x7 CORVETTE RALLEYS WITH NEW BFG TIRES ON THE FRONT AND 15X8 IN THE REAR WITH BRAND NEW M/T ET STREET DRAG RADIALS 275/50/15S THIS CAR STILL NEEDS A LIL TUNEING AND GEARS WOULD GO WITH 4.10S HAS NOT BEEN RACED AT ALL THE MOTOR WAS IN A FRIEND OF MINES 72 CAMARO WITH THE SAME TRANS WITH 4.56S AND WENT 11.40S ON ALL MOTOR SHOLD GO MID 10S ON SPRY
the guy is asking $8,000. Is that a good price. how much do you think its worth?
Old May 21, 2009 | 11:53 PM
1969 SS's Avatar
way too much to read with the thread all in caps and no punctuation.
without even reading any of that (posts like that give me a headache), I will say that anyone that even tries to give you an estimate without seeing DETAILED pics of the car, is guessing at best
Old May 22, 2009 | 12:00 AM
rancheronut's Avatar
wow ! talk about being in code? can't do brian work over the phone. so needs good photos before i could even guess.
bobarian91
Oct 2, 2008 03:33 PM
MrBlonde
Jul 6, 2008 10:19 PM
CBowman622
Jul 2, 2008 07:18 PM
makowski
82-92 V8 Tech
15
Aug 12, 2007 10:51 PM
