how do you cut floor boards out?
Old Aug 14, 2009 | 11:01 AM
daleas88's Avatar
Default how do you cut floor boards out?
what do you use to cut out floor boards? a grinder or torches or what?
Old Aug 14, 2009 | 02:41 PM
I use a cutoff wheel and a sawzall. The sawzall does most the major cutting, but sometimes the cutoff wheel in my rotary grinder needs to be used for hard to reach places.
Old Aug 14, 2009 | 10:53 PM
bowtieguy's Avatar
July 2009 ROTM
dont use a torch,it will warp the remaining metal and leave you with a lot of grinding,.i used a air cutoff saw withe 3" disc and it worked fine
Old Aug 14, 2009 | 11:01 PM
It would also be advisable to remove your gas tank and store it somewhere safe. You're gonna be throwing a lot of sparks around, plus accidentally hitting the gas line can make the car and you go boom!
Also, removing the interior goes without saying....I hope.
Old Aug 14, 2009 | 11:10 PM
I use a 4" cutting wheel in my 4" grinder. I have them .032 thick. I like to put the floor in place and cut the new pannel and old pannel at the same time. Here is how the pros do it.
http://v8tvshow.com/content/view/770/1/
Old Aug 15, 2009 | 01:34 PM
That's a great video, and definitely the best way to repalce a floor pan, but probably not realistic for most average hobbyists. I sure don't have a rotisserie, nor the room to do one that way.
pheonix782
Jan 25, 2012 08:15 PM
MeanGreen3.4/5
Dec 24, 2008 02:13 PM
season07allday
Apr 13, 2007 06:18 PM
Fossil_160
Jan 19, 2006 05:20 PM
scauntay
Jul 31, 2005 05:46 AM
