Hood Swap
i've toyed with the hood moving it forward and back and where i have it sits just perfectly. however i've toyed with moving it left and right and i've yet to hit the sweet spot. whenever it a lines up nicely on one side it's way off on the other, and there seems to be no in between. I attributed that to the bow which i decided needed fixing first.
Rizzo, good thought, however it was my short coming by not stating that this hood has a 3-6inch hood scope. To add to that, i don't have a filter on the engine yet. Plan on changing out the carb
Well that helps a lot! If the bow is in the middle on each side you might try taking the rubber bumpers off the sides that are on the fenders. They just slide into a slot and can be temporarily removed to see if they are causing the issues. Mine even caused my steel hood to bow up on the sides, so I removed them and thinned them out on my belt sander until they just touched the hood on each side.
No, that was my first thought but he says in the third post:
It's not hitting the rubber "bumpers" on the sides either...
I got my camera back! sorry for posting my question without the aid of a photo. Thanks for all ya'll suggestions and help. I'm still working on it. Maybe these pictures will help us figure this out.
also, a side note, you see it's only bowing real bad on the passengers side. When i adjust it, it just favors one side, there doesn't seem to be a happy middle, either the left or right side bows real bad and the other just so so.
(passengers side)
(front...lines up nicely IMO)
(drivers side)
(passengers side)
(drivers side)
Is it even bolted to the hinges? WTH? Can you raise it up and give us a pic of what's going on under there? For the back to be up that high on the passenger side the hinge can't be compressing/folding into it's proper closed position.
The springs were mentioned earlier, but you didn't say if you did anything with them. The factory heavy duty springs are designed to support a heavy steel hood and HAVE to be removed when putting on a fiberglass hood. The strong springs could be trying to lift the hood where it sits. The extra tension is also bad for the glass hood as it will stress it too much when closing and you'll start to get surface cracks, taking the paint with it. Remove the springs, and then try to make adjustments. Hardware stores sell lightweight springs that will work well with the glass hood, it doesn't need much tension to hold the hood up.
#20
Wow! That's really pulling hard on the hood, and looks seriously like it will break it if it continues without addressing the springs. I'd remove tham to test it, and also make sure the spring pivot points are lubed with some spray lube too! I've seen hinges that felt OK when closing, but actually bent a steel hood because they needed lube in the pivot points.
