Hood Latch Issue
Hard to say what your hood issue is. Will it not latch, or what? If it was mine I'd loosen the centering pin and turn it out several turns. Then try to latch the hood. If it wont latch try a few more turns out and see.
Once you get it to close and latch, then you can turn it back in until it's adjusted corectly and tighten the locknut.
Rectangular type? Are you referring to the latch that attaches to the radiator support and upper valance? What about the hood side of the latch? Doesn't it have a round pin with a semi pointed end? That's the part that adjusts.
