help guys what gear do i order
Old Feb 12, 2007 | 05:18 PM
MIKESYENKO's Avatar
April 2007 ROTM
Default help guys what gear do i order
Ok i figured out my car has 456 gears or lower and i red line at like 60 mph in fourth gear so i need to change the gears in it what should i change it to ?????I want something i can cruise with but still kick some but at the track.I also need alittle help to figure out this slide a link traction system i dont know alot about that either.
Old Feb 12, 2007 | 06:04 PM
bowtieguy's Avatar
July 2009 ROTM
Default RE: help guys what gear do i order
i would say 3.73's or keep the gear you have and get a overdrive.i dont know what the name of the unit is called but they make a overdrive unit that bolts on to the back of your tranny.then you have the best of both worlds,low gear for the track and high gear for cruising
Old Feb 12, 2007 | 06:30 PM
rat454's Avatar
don't thing gear venders makes an add on od for a 4 speed manual...
I switched the to tremec to get the OD..it works well, however for your use i would agree to just simply changing to 4.10's or 3.73 will probably be your least costly option and get you into the ball park based on your needs.
do you know what type 4 speed you have?
from your other posts it sounds like it was set up to do the 1/8 mile..
A hell of nice looking car...
can you take a digital of the rear traction system and post it?
Good luck
G
Old Feb 12, 2007 | 07:22 PM
MIKESYENKO's Avatar
April 2007 ROTM
454 C.I.D. 10:1 COMPRESSION, COMP.CAM, GEAR DRIVEN, HEADS PORTED AND POLISHED, 2.19 INTAKE VALVES, 1.88 EXHAUST VALVES, HOLLY 850 D.P., FULL 3" EXHAUST SYSTEM, I DON'T KNOW THE BRAND NAME OF HEADERS,I THINKTHEY HAVE BEEN COATED. THEWHEEL WELLS BACK IS CHROME. IT HAS A CENTERLINE CLUTCH. IT HAS A RICHMOND 4 SPEED, 2.88 1ST. GEAR. 12 BOLT G.M. POSI Hope this info helps
ScottD
Aug 30, 2023 05:45 AM
3.4putter
Jan 28, 2012 07:35 PM
Bing
Jun 3, 2010 04:27 AM
redreffitt
Apr 23, 2008 01:21 AM
00camaro00
LS Series Tech
Mar 15, 2007 08:50 PM
