Help with 350-454 swap
Old Jan 20, 2011 | 02:56 PM
Gen2-454's Avatar
Default Help with 350-454 swap
ok originally the 78 z28 had the 350, but i bought it with a 454, its not bolted in right now and im wondering if i can use the stock motor mounts.
Also i know i need heavier springs, im also planning on moving my battery to the back and getting rid of the a/c components to lessen the weight.
Would i need to upgrade my radiator, starter, etc...?
If so, what all would i need to replace to match up with this mark IV 454.
I'm getting the t-56 magnum conversion from hurst also so im already upgrading the clutch flywheel etc..
Please help me with this, i just started about 6 months ago on restoring/rebuilding. Thanks!
Old Jan 20, 2011 | 10:29 PM
Use the same motor mounts.
Springs are fine, it's only 100 lbs. heavier.
Bigger radiator, and starter are needed. Could use the same starter for awhile, but it will eventually fail. Not sure what a hose pump is?
Hood wont clear, so you'll need a scoop or cowl hood.
Old Jan 20, 2011 | 10:50 PM
Gen2-454's Avatar
it came with a 4 in cowl heh
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
