head gasket??
Old May 27, 2008 | 06:19 PM
thebandit110's Avatar
Default head gasket??
ok, so a few weeks ago i noticed some anti-freeze on my starter motor. not much but it was there. than it got a little worse. like the starter is not covered with coolant but its a little wet. than i thought i fixed it by changing the freeze out plugs. ( one was sorta rusty) than i notice it again yesterday and it looks like its coming from between the head and the block? does that mean its a head gasket or could the head be warped? any ideas???
Old May 27, 2008 | 09:06 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: head gasket??
Yes, it could be the head, but,,,
Before you go to the extent of tearing down the engine, pressurize the cooling system and get mirror to check the rear of the intake. Many times it is the rear water passage and not the head. The coolant can run down and look as though it is coming from the head. If it turns out to be the head, there is always a chance of warpage. You'll have to check them.
Old May 27, 2008 | 10:24 PM
yeah i checked the back of the motor with the system pressurised and nothing. i tried to post a picture before, but it didnt work. you can see where its running down the side of the motor. so im gunna assume its the head gasket.
hyflyr
Feb 21, 2012 08:26 PM
keaboi
Aug 26, 2011 08:01 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
ryden
Mar 14, 2010 05:30 PM
dcanada53
Mar 5, 2008 06:01 PM
