Has anyone tried this?
Old Oct 12, 2006 | 06:54 PM
TSTONE's Avatar
Default Has anyone tried this?
has anyone found an HEI that will fit a 68 327 without modifing the firewall
Old Oct 12, 2006 | 07:15 PM
SickSickSick's Avatar
Default RE: Has anyone tried this?
try an MSD pro-billet standalone distributor. it should fit. Sick
Old Oct 12, 2006 | 07:19 PM
TSTONE's Avatar
I'm looking at those also (both Pertronix & MSD) but my understanding was pro billets are different than hei's - in that they are just a pointless distributor versus a coil on cap - and that they produce a lower spark duration?
Old Oct 12, 2006 | 08:53 PM
GRIFF's Avatar
The coil on my pro billit is external and I have a ignition box also the probillit is superior than a stock gm hei unit in higher rpm performance applications.
Old Oct 12, 2006 | 09:23 PM
uncle bill's Avatar
An MSD Pro Billet is a HEI ( High Energy Ignition ) with an external coil. GM put the coil into the cap on HEI's for a number of reasons, one of which, was to eliminate the problem of loose coil wires in Grandma's Impala. I have a GM HEI in My '69 427 Camaro, but it's a factory big block car. I don't know if the small blocks were set farther back or not. My firewall isn't modified.
