groan in rear end
Old 11-29-2010, 06:03 PM
jason7504's Avatar
ok well here are some test results from the test drive:
*makes a grown/howl when turning wheel
*when coasting with foot off gas and in drive- the howling/whirling sound is still there
*when coasting in netural-still makes the howling/whirling sound
*when coasting under 30mph-sound is still there
*get's louder as speed increases
tomorrow i'm gonna swap wheels/tires and see if sound is still there to eliminate wheels/tires as a cause
  #22
Old 11-29-2010, 06:41 PM
kyles_81camaro's Avatar
are you sure its not a u-joint in the drive shaft making the noise??
  #23
Old 11-29-2010, 07:14 PM
Since the noise didn't go away when coasting in neutral, I'd bet it's not U joints. They usually make the most noise when under load. Speeding up and slowing down in gear.
  #24
Old 12-07-2010, 02:20 PM
kyphur's Avatar
Originally Posted by jason7504
I can't remember if i had them balanced when i had the tires mounted but i wanna say that they weren't because the guy said that you don't need too with these good quality tires (mickey Thompson's). I know that Cragar's can vibrate since there hard to get centered with the uni-lug pattern too.
That's bad advice right there. The rims could be out of balance if they're poorly made. I don't think I've ever seen a setup that didn't need tire weights.
  #25
Old 12-07-2010, 06:21 PM
Yes, very bad advice. Speaking from experience with MT tires, they can require a bit of weight to get them in balance.
  #26
Old 12-07-2010, 08:11 PM
Doesn't matter what kind of tire or wheel, a tire mounted to a wheel and not needing any amount of weight to be perfectly balanced doesn't exist.
rs657f
07-29-2015 04:00 PM
rs657f
03-12-2015 06:25 AM
Saaampson74
10-20-2008 04:56 PM
libertyforall1776
11-10-2007 03:04 PM
Quick Reply: groan in rear end
