Gauge Cluster Wiring
Old Aug 25, 2012 | 12:32 PM
WatsonCustoms's Avatar
Default Gauge Cluster Wiring
Ok, so I just bought some new tires and rims.( 17" Torq Thrust II with 245/40 michelins) anyhow, my gauge cluster is way off! I've yet to put these tires on, but I need some help. My gas gauge doesn't work, my speedometer reads 120 when I'm goin 45 and all the other gauges are off as well. Would it be best/ cheapest to buy an aftermarket set of gauges or is there any way of buying a wiring kit along with a sensor for the gas tank? Also, what gear do I need to fix the gauge. It went from original camaro cluster to z28 cluster.
Old Aug 25, 2012 | 08:21 PM
Ok first things first. I take it you installed gauges in a car that came with idiot lights?
Its not a Z28 thing. Its call a U14 gauge cluster. U14 is the RPO for gauges, available in any car with a v8.
You simply need to swap the wires around in the plug going to the back of the
gauges. Here ya go step by step. 2GCOG - U14 Gauge Swap
The fuel tank doesn't get a sender when you go aftermarket. You must get one that is works on a 90 ohm scale.
What gear for your tranny?
Old Aug 26, 2012 | 09:13 AM
B.M.'s Avatar
Yeah,the only senders you will need is for oil and water temp,unless your factory fuel sender just doesn't work,but i would try the gauge first.If your speedo is that far off,i would guess a bad speedo,i can't imagine changing the gears in the tranny would change the reading by 75 mph,i could be wrong,just doesnt sound like it would unless it is a drastic gear change.
Old Aug 27, 2012 | 10:13 AM
Sorry for the confusion about the gear. Not a tranny gear, but I was told the gauge has a gear in the back of it.
Old Aug 27, 2012 | 12:27 PM
The speedo does not have a removable gear.
bd92rs
Apr 2, 2009 07:54 PM
19 camaro 84
Jun 19, 2008 08:29 PM
z28scorpio
Mar 14, 2007 10:27 AM
