Gas Pedal Pin and Spring Assembly
Old Sep 20, 2009 | 03:03 PM
Franksflying1's Avatar
Default Gas Pedal Pin and Spring Assembly
How the heck do I put tthe gas pedal back on? I have a new pedal, new pin and new spring but cannot figure out how it all goes back together. I know its probably super easy but I cant figure it out. Any pictures or easy instructions out there?
Old Sep 21, 2009 | 10:20 AM
McGnrAcDcfan227's Avatar
You took your gas pedal off? Why? Was it broken?
Old Sep 21, 2009 | 05:25 PM
What year is your Camaro?
Old Sep 22, 2009 | 10:27 AM
The car is a 1970. I did figure out last night. First step is to remove the gas pedal assembly by removing the three bolts that go up against your firewall. Once you have that removed you can take the pedal armature off completely giving you the luxury of not having to try to fix it upside down under the dash.
rchate1
May 6, 2014 11:30 AM
Gen1admirer
Feb 16, 2013 11:36 PM
tattoo400
Jul 15, 2012 01:52 PM
69SS427
Apr 15, 2011 08:10 PM
hunterscamaro
Nov 18, 2009 11:10 PM
