Gas Pedal Pin and Spring Assembly
How the heck do I put tthe gas pedal back on? I have a new pedal, new pin and new spring but cannot figure out how it all goes back together. I know its probably super easy but I cant figure it out. Any pictures or easy instructions out there?
You took your gas pedal off? Why? Was it broken?
What year is your Camaro?
The car is a 1970. I did figure out last night. First step is to remove the gas pedal assembly by removing the three bolts that go up against your firewall. Once you have that removed you can take the pedal armature off completely giving you the luxury of not having to try to fix it upside down under the dash.
