Floor Shifter
Old Apr 4, 2008 | 05:01 PM
Nightstalker's Avatar
Default Floor Shifter
I am installing newcarpet in my 1975 Camaro and I have the console loose but I can't seem to figure out how to take the shift **** off so I can remove the console. Any help would be appreciated.
Old Apr 4, 2008 | 05:13 PM
thebandit110's Avatar
Default RE: Floor Shifter
first you take a small screwdriver and lift the *** up, there will be a place for you to stick the screw driver and pop that off, than on the inside of that there is a clip, you need a small pair of plyers and take that clip off and the **** will come out and the rest is pretty self explainitory. hoped this helps.
Old Apr 4, 2008 | 05:55 PM
Thanks very much I knew there was a trick but I couldn't seem to find it.
Smokin70camaro
Dec 28, 2012 01:15 AM
67LS3
Jun 1, 2011 10:06 PM
BasicConcepts
Sep 11, 2010 10:36 PM
Time Hybrid
Feb 15, 2010 11:42 PM
420GOAT
May 10, 2007 06:33 PM
