Engine Pad Number What is this?!?!
Old Aug 14, 2008 | 11:22 PM
porkandrice's Avatar
Default Engine Pad Number What is this?!?!
Only found three numbers on my block. FYI bellhouse and transmission connected.
1) V0419800 found on the pad between the alternator and passenger side valve cover. CAN NOT*** find number like this on internet. checked 15+ suffix/code listing sites thoroughly. nothing. all i gather is its Flint; April 19th. i assumed its 80 but i really have no idea what the last three mean.
2) Located just above the oil filter were two sets of digits written upside down. 207 on top of a 11N.
3) 379 written on the walls of the block.
new to chevys. school me.
cheers
Old Aug 15, 2008 | 01:23 AM
dodge destroyer's Avatar
Default RE: Engine Pad Number What is this?!?!
I think what u have is a replacement Crate Motor. not factory but a over the counter replacement. if that makes sense.
Old Aug 15, 2008 | 06:50 PM
kyphur's Avatar
The first number you have is the VIN number. You should be able to compare it to your car's actual VIN and see similarities if it's a numbers matching car. If you're looking for a casting number you should find it behind the driver's side head right beside the bellhousing. Mine has two numbers above the oil filter and are 010 and 020 and I'm told those are the metallurgical contents and should match with the ones behind the timing cover. I'd need to see the 379 to tell you what that is since I have no clue right now.
My engine's also an earlier engine and possibly has different coding than yours. Have you tried checking Moretec?
Old Aug 15, 2008 | 07:02 PM
kyphur's Avatar
Check these two links:
Number One
Number Two
That site will also help decode the numbers once you find them.
You may also want to check here.
Of course I'm assuming that it's the 1981 Camaro that you have in your sig...
Old Aug 16, 2008 | 02:33 AM
yes yes. didnt mention it IS the 81 in my sig. its not the original engine as she came with a 6 cyl.... according to the vin.
racersdad04
Dec 23, 2008 09:02 AM
racersdad04
Jun 20, 2008 12:32 PM
remoulds
Jun 4, 2007 03:53 PM
Dhunter
Apr 28, 2006 12:53 AM
burntrack
Apr 23, 2006 11:14 PM
