Dropping the front of a 1968??
Hi, new to the forum... Thought I'd fire out a question and see if I can get some help. I have a 1968 the I'd like to drop in the front. The problem is, the tires rub the inner fender if I go any lower than where I'm at. I've played with the offset of the wheels and they're about as good as I can get them. Is there a way to modify the inner fender or do I need to remove them? Thanks!
Well if ur car is rubbing the fenders now I wouldnt go any lower. But if u are rubbing u could raise the car back up or remove the fender wells all together. How did u lower the car with drop springs or heat the springs or coil over?
