Dog chewed my bumber
Old Mar 28, 2007 | 08:39 PM
Stuart's Avatar
Default Dog chewed my bumber
WellI have a rottweiler puppy and she decided to rip a chunk out of my bumber ...
Any body have any suggestions on how I could fix something like this?
Any help would be great, Thanks
[IMG]local://upfiles/4705/D9CEE8447A244E0B907D5B40389AE8B9.jpg[/IMG]
[IMG]local://upfiles/4705/2AA45FC117994FB79852A575B683DE02.jpg[/IMG]
Old Mar 28, 2007 | 08:58 PM
Blade's Avatar
June 2007 ROTM
Default RE: Dog chewed my bumber
well did u chew on his leg?
bondo or a new bumper.
Old Mar 28, 2007 | 09:59 PM
74454bb's Avatar
May 2007 ROTM
use some fiberglass resin and cloth. then smooth it out with tiger hair. (bondo with fiberglass threads)
Old Mar 28, 2007 | 10:55 PM
Stuart's Avatar
Thanks, I'll try and pick some up for this weekend. Does it come in a kit, and if not do I need anything special to smoothe it all down?
Old Mar 28, 2007 | 11:07 PM
74454bb's Avatar
May 2007 ROTM
you'll need some 80 grit up to 600 grit paper, some cheap paint brushes rubber gloves , a can of resin and a bag of the cloth, also a can of the bondo. You may be able to get the resin and cloth in a small boat repair kit. If you go to a car parts store they should be able to find the stuff for you. you'll want to clean the bumper real good and scuff both sides with the 80 paper. then (on the back side)brush on the resin,and lay a few 3 inch strips of cloth and coat with more resin. don't leave any air bubbles. this has to be done quick,the resin hardens within 5 min. wait about 30 min then use the bondo to smooth out the hole. Make sure to read the mixing directions. once you start to work with it you'll catch on. These links may help. http://www.boatus.com/boattech/casey/17.htm
http://www.ehow.com/how_2002643_repair-fiberglass.html
tagius
May 11, 2013 08:52 PM
mr.blue
Nov 19, 2011 12:46 AM
dyonts
82-92 V8 Tech
Jan 21, 2009 01:12 AM
Reaper3000GT
Sep 9, 2007 01:56 PM
Don Hog
Aug 11, 2006 01:36 AM
