Competition Engineering Formed Rear Frame Rails
Has anyone here ever used these instead of stock style. Cutting and welding I don't really care about. Just want to know if anyone had a thread covering the install. Comp says if you use their weld in frame (which I already bought) connectors then the frame rails are a must. I'm fine with that. I would like to see what they look like installed and some tips on things to look out for. Also there moved inboard, but how far? Will my fuel cell fit between?
Their frame rails are OEm replacement, but stronger. They go right back in place where the factory rails were. No difference in dimensions, just heavier.
