Car parts with rust!!!!
Old Oct 15, 2011 | 01:18 PM
Jeepin's Avatar
Default Car parts with rust!!!!
Alright guys quick question I have some metal parts that have rust on them and they can be removed so the question is do you guys have any experience with the rust removers where you set up like some kind of bath and add the liquid then you place the metal part in let it sit then 'Alah Kazam' no more rust!!! Any help will be appreciated thanks
Old Oct 15, 2011 | 02:18 PM
BasicConcepts's Avatar
Technical User
Ive use a product before can't remember what it was called tho but it worked pretty good I took a wire wheel to it first then put it in the bath then a nice coat of paint to protect it (ill try to find out what its called when I get off work)
Old Oct 15, 2011 | 02:43 PM
Jeepin's Avatar
Alright thanks much appreciated
Old Oct 15, 2011 | 02:58 PM
Then two years down the road. Ala kazam no paint. Not a good idea bro. You may not get the rust remover off well enough and cause paint adhesion issues. Sandblast or good old sanding.
Old Oct 15, 2011 | 03:56 PM
Technical User
The rust remover is water based safe for the environment all you do is rinse with water and your good (I used it prob 5 years ago on an umbrella stand the paints still good and no rust
Old Oct 15, 2011 | 04:49 PM
Jeepin's Avatar
alright thanks for your help i will probably not use it on things im going to try and paint but i was going to use it for some parts that i didnt need to paint just wanted to clean them up a bit!!!
Old Oct 15, 2011 | 07:26 PM
lbzraptor's Avatar
POR-15 seems to work pretty well. It lifted some rust that wasn't pitted off a door i have that sanding didn't get. I believe without looking it was called marine clean
Old Oct 15, 2011 | 10:01 PM
I've used rust neutralizers, but not the stuff that simply removes rust. The neutralizers turn rust into solid material that can be sanded, ground or painted. I did numerous spots on my old '46 Austin about 14 months ago, and they still look great.
Old Oct 18, 2011 | 07:26 AM
78bluers's Avatar
hey jeepin just to let you know i do sandblasting and sodablasting if there small parts you can box them up and send to me in maryland ill blast and prime and ship them back... great prices
Old Nov 8, 2011 | 05:55 PM
bad436z28's Avatar
yeah the marine clean and por-15 are a great product and lasts a long time,good luck.
lowco8
Aug 13, 2012 06:36 PM
LessThanDrew
May 2, 2009 07:12 PM
Jackpot4
Apr 16, 2008 08:34 PM
snake10556
Jan 14, 2008 06:48 PM
The Corvette Doctor
Nov 20, 2007 12:23 PM
