camaro leaning to the right
Hi, my 1969 camaro is a clone Z28, I noticed that it had startedleaning to the right, I replaced the shocks then all of the springs, I thought the springs would take care of the problem but i did not.Any ideas as to what might be causing this??? could it be the Subframe bushings????any help would be appreciated. Thanks..
Have your leaf springs rearched. Or swap them from one side to the other and see if it changes. You can also measure on each side between the springs, axle tubes, frame ...and see if it is different from one side to the other. That will give you an idea of where the lean is comming from.
I had just remebered. I was working with a body man, More of a customizer from the 60s'-70s'. He was working on a car that was in an accident and he would not let up that the frame was bent because the car was leaning. So the frame man got the job and put the car on the rack. Took his squating relax position with a ciggarette, looked carefully, and went to his tool box and got a tire gauge and inflated the tires to proper psi. The car was fixed!
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
