Camaro Carb
Old May 3, 2006 | 01:58 AM
Camaro_Z28's Avatar
Default Camaro Carb
I want to put a new 4-barrel carb on my 81 Camaro Z28. It has a 350. What is the best kind for it.
Old May 3, 2006 | 08:11 PM
SickSickSick's Avatar
Default RE: Camaro Carb
Depends On Who You Ask And How Much You Wanna Spend. Best Quality And Reasonable Price ... Holley. If You have An Automatic Stick With Vacuum Secondary . If Standard Go With A Mechanical Secondary. Using The Formula If Your Motor Is All Stock A 650CFM Should Be Plenty Of Carb. Sick
Old May 3, 2006 | 09:32 PM
Camaro_Z28's Avatar
I like holley but whst about an eldebrock carb?
Old May 3, 2006 | 10:54 PM
TimmyTheWop89's Avatar
edelbrocks dont make as much raw horsepower as say a holley or barry grant, but they are easy to tune, and run very smooth. if you are running a stock motor and plan on keeping it less then 320 horsepower, then an edelbrock 600cfm will work fine. i currently have a temporary 600cfm edelbrock on my 350, and it has a good amount of mods, pushing around 360 horsepower, thanks to a desktop dyno, which isnt fully accurate. the carb has awsome throttle response, and runs very smooth, although starves for air at high rpm's.
Old May 4, 2006 | 01:41 AM
v8chvyguy's Avatar
I have owned both Edelbrock and Holley carbs. I have found both to be fairly good quality and responsiveness, however, they did require a bit more attention than the stock Q jet. I never could get them to run as reliably or as smoothly as the Q jet, I ended up switching back to the Rotchester. I hav'nt had to tinker with a carb since. Keep in mind though, that I am running stock motors.
Old May 5, 2006 | 01:14 AM
Camaro_Z28's Avatar
My engine is stock so im looking for more horsepower than anything.
Whats the best for it?
Old May 7, 2006 | 12:59 PM
v8chvyguy's Avatar
Anywhere between 400 and 600 CFM anymore on a stock motor and you start overfueling, robbing you of power. Lean is fast, but, it can wreck a motor. Since it's stock I'd suggest leaving the stock Qjet on there, from what I've seen, it can fuel upto about 300 HP. Are you planning some engine mods before you do the carb? Because the carb dos'nt really make HP, it feeds it. You need to increase volumetric efficency(the motors ability to pump air) before you start adding more fuel. Intake, heads, and exhaust do that.
Old May 7, 2006 | 01:49 PM
Camaro_Z28's Avatar
Yah i am going to do some engine mods before i put a new carb on. I want to put new heads and intake on it before i do anything else. I had a new 3" exhaust system put on last year.
Old May 7, 2006 | 10:30 PM
if you do a simple bolt on upgrades such as exhaust, heads and intake, then a holley or barry grant 650cfm is the best suited. i wouldnt advise going bigger, i know a guy that used a 750cfm barry grant on a 454 and it ran like crap on initial launch, way overcarburated. 650cfm is plenty of breathing room.
Old May 8, 2006 | 01:45 PM
Camaro_Z28's Avatar
Ok thanks, ill try that and see how it works out!
Libert
82-92 V6 Tech
10
Nov 19, 2011 01:15 PM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Mesosneaky
Jun 7, 2009 11:28 AM
Black79RS
Jan 31, 2008 11:48 PM
1969 Camaro
Oct 12, 2006 03:18 PM
