Body Panel help
Hey guys,
I picked up an 81 Camaro a couple weeks ago, just been going through it and getting it running good. Now on to the ugly issues... Is there anywhere that sells a patch panel for the metal in FRONT of the rear tire? I haven't seen one, but as you can see I need one (and a rocker, and a door skin lol) Thanks a lot for the help. If not I guess I will be searching through some junk yards.
I do not think the body work that was exposed was done by a pro. Like Greencamaro said strip everything before ordering. 3/4 quarters (or quarter skin) are cheap and a lot easier then 2 or 3 patched.
Nothing wrong with bondo but it should never be thicker the .060-.070" (1/16"). You sure don't want to spend money on a paint job unless you sure of what you are putting is on.
https://www.autobodyspecialt.com/cgi...on&key=CA-7-LH
moparmusclecars
Feb 1, 2014 06:32 AM
