BIG PROBLEM
Old Jul 31, 2008 | 07:59 PM
irocktheIROC's Avatar
Default BIG PROBLEM
ok so what do i do you guys, my rear frame rails are rusting through right at the bend in front of the rear axle, like just before it goes up in the bottom side. what can i do to fix this?
Old Jul 31, 2008 | 08:32 PM
kyphur's Avatar
Default RE: BIG PROBLEM
You can try this...
Old Jul 31, 2008 | 09:43 PM
ugh...im an idiot...how much does it cost to get them installed you think? and i have to take my whole *** end out huh...damn... will all my **** bolt back in?
Old Aug 1, 2008 | 09:46 PM
kyphur's Avatar
Well, you could go to Heidt's or Chris Alston's and get the entire performance rear ends.
Old Aug 1, 2008 | 10:11 PM
dude...i barely have money for gas...
Old Aug 1, 2008 | 10:21 PM
kyphur's Avatar
ha ha, I feel your pain, truly. If you lived close I would offer to help free of charge and I could possibly bring a few mechanic and body guys occasionally.
Old Aug 2, 2008 | 01:29 AM
bowtieguy's Avatar
July 2009 ROTM
ORIGINAL: irocktheIROC
aint nothing cheap on these s.o,b.'s except for the water you put in the radiator.can you cut one out of another car ,dress it up and weld it into your car.you would have to do alot of measuring
Old Aug 2, 2008 | 12:50 PM
damn....camaro is pain...but i cant get away from it! idk ill see if i can go to the junkyard monday, will the *** end outof a 76 fit it? thats all that is out there really...
Old Aug 2, 2008 | 01:19 PM
kyphur's Avatar
I think the frame rails are the same from 70-81, floorpans are different from 70-74 and 75-81 if I remember correctly.
Old Aug 3, 2008 | 05:47 PM
so i can just unbolt the frame from a 76 and bolt it all in or what?
