battery power draw problem - pulled all fuses
Old Jan 7, 2012 | 09:17 AM
  #21
Originally Posted by mike6208
yea i tried that, so i went ahead and started pulling the red wires away from each other where everything meets, a/c, starter, fusebox wire.
i took off the starter wire and my draw went away.
Are you talking about the red wire that's on the same lug as the battery cable? If so, that's the wire that powers the entire car unless there's an added jumper wire at the battery (starter is used as a junction block), and it would make total sense as to why the draw stopped when disconnected, you killed power to everything electrical. Another thing I didn't see you mention checking is the horn relay on the radiator core support, it's also used as a junction block. Not everything electric on the car is fused, some are connected directly from the battery with in-line fusible links, horn relay is one of them.
Old Jan 7, 2012 | 10:52 AM
  #22
mike6208's Avatar
hm, ill go out today and start trying some of those things and post back, thanks all
mikemnbvcxz
Jun 17, 2013 10:32 AM
kferg
Jul 20, 2011 06:34 PM
randolphdelpriore
Sep 17, 2009 12:14 AM
BAN WS6
Dec 10, 2008 12:56 PM
shiggy
Oct 14, 2005 01:52 AM
