79 Z28 fuelpump pushrod dropped (how do I raise it?)
#42
RE: 79 Z28 fuelpump pushrod dropped (how do I raise it?)
i couldnt find 0137460391.did this #come from the back of the motor on the drivers side on the bell housing part of the block.you can go to www.mortec.com and look up these #
#43
#44
I got these numbers from the front of the block behind the alternator on a little ledge, I will check them again if you do not think they are correct
#45
http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.phpThis should be the suffix codes I tried to cut and paste but it didnt work[:@]
[align=center][/align]
#46
block# is on the drivers side, rear of the engine,on the bell housing part of the block.the # you got will tell where it came from,when it was built and what car it was put in.the # at the back of the block will tell you what the engine is.
#47
The number on the back of the block is the casting # it may be a number which spans through a number of years and also cubic inch displacements. The numbers he gave if they were correctwould be the more accurate of telling what engine it is, JX what are you looking for ? I think the 0137460391 may be a letter instead of a #.
#48
I guess what I am looking for is to find out if this is the original 350, or if it is something else.
OK these may be better
013Z460391 and VO423CKK
The CKK comes back as a 74 Monte Carlo 350or a73 BAX?
#49
I got flint april 23 http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php 72 or 73 look under the ckk code the longer one throws me off unless you disregard the 0
