79 Z28 fuelpump pushrod dropped (how do I raise it?)
Old Feb 9, 2007 | 03:33 PM
  #41
jxdesign's Avatar
Default RE: 79 Z28 fuelpump pushrod dropped (how do I raise it?)
0137460391
V0423CKK
Best I can see right now
Old Feb 9, 2007 | 04:12 PM
  #42
bowtieguy's Avatar
July 2009 ROTM
i couldnt find 0137460391.did this #come from the back of the motor on the drivers side on the bell housing part of the block.you can go to www.mortec.com and look up these #
Old Feb 9, 2007 | 04:58 PM
  #43
GRIFF's Avatar
http://www.nastyz28.com/sbchevy/sblock.html#ecode
Old Feb 9, 2007 | 11:35 PM
  #44
jxdesign's Avatar
I got these numbers from the front of the block behind the alternator on a little ledge, I will check them again if you do not think they are correct
Old Feb 9, 2007 | 11:43 PM
  #45
GRIFF's Avatar
http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.phpThis should be the suffix codes I tried to cut and paste but it didnt work[:@]
[align=center][/align]
Old Feb 10, 2007 | 02:01 AM
  #46
bowtieguy's Avatar
July 2009 ROTM
block# is on the drivers side, rear of the engine,on the bell housing part of the block.the # you got will tell where it came from,when it was built and what car it was put in.the # at the back of the block will tell you what the engine is.
Old Feb 10, 2007 | 02:30 AM
  #47
GRIFF's Avatar
The number on the back of the block is the casting # it may be a number which spans through a number of years and also cubic inch displacements. The numbers he gave if they were correctwould be the more accurate of telling what engine it is, JX what are you looking for ? I think the 0137460391 may be a letter instead of a #.
Old Feb 10, 2007 | 03:36 PM
  #48
jxdesign's Avatar
I guess what I am looking for is to find out if this is the original 350, or if it is something else.
OK these may be better
013Z460391 and VO423CKK
The CKK comes back as a 74 Monte Carlo 350or a73 BAX?
Old Feb 10, 2007 | 04:17 PM
  #49
GRIFF's Avatar
I got flint april 23 http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php 72 or 73 look under the ckk code the longer one throws me off unless you disregard the 0
Old Feb 10, 2007 | 06:08 PM
  #50
ghotachevy's Avatar
the zero is just a dot from the mold
