79 tilt steering column
Unless you have some old ball aftermarket collum there are no press fit bearings. I am not sure what you mean by top bearing. Do you mean the bearing on the right below the steering wheel but in the tilting section? If I remember right this bearing has round ***** and a cage on one side. It is an angular contact bearing. There is a race in the title section then a cup that goes next that is the other side of the race. Just be sure the cage does not touch anything when you assemble. the bearing and you are good. I don't remember if the is a right way. I cannot remember seeing one and saying they got that backwards. Once it all together you need to compress the spring then a snap ring holds everything together.
Sorry I am a little fussy Collums where one of my specialties, but I have done so many designs they blend together. I picture would help.
