79 camaro lights issue
Old Mar 22, 2009 | 09:20 PM
NightWolf's Avatar
Default 79 camaro lights issue
Hi there still new to this forum but anyway I got a 79 camaro and a light issue hopefully someone can help me on now dash lights work and outside lights to a digree. for the evening i got on left back tail light on but not the other? now for the front the right blinker goes on and blinks but when i do the left its just steady no blinking. and may be dum question but is there even a low light beam setting or just the high ones when u pull back the *** and also when i have that *** pulled back the left turn light on the dash lights up? so hopefully someone may be able to help me here.
Old Mar 23, 2009 | 05:51 AM
80rsguy's Avatar
well stat by replacing your bulbs i think the number is 2057 but im pretty sure 1157's will work to and it sounds like your flasher is bad minw did the same thing when i got it it ended up being the flasher its on your fuse box under the dash on the driver side
.I work at checker auto and the falsher i bought is a FL32 that should fix her up for ya
Old Mar 23, 2009 | 11:36 AM
NightWolf's Avatar
Ok cool thanks and also is there a low beam setting on these old cars? cause i only get it bright when the *** is pulled right back.?
Old Mar 23, 2009 | 02:02 PM
Domobomb's Avatar
Well there's just your lights or your highbeams. Do your highbeams work?
Old Mar 23, 2009 | 07:35 PM
NightWolf's Avatar
well when I pull the *** thing all the way back lights go on and a blue light on my dash its pritty bright so i assume its the high beams but when the car is turnd on no head lights come on.
Old Mar 23, 2009 | 08:30 PM
BurntTreez28's Avatar
i have a 78 camaro and the highbeam switch is down on the floor to the left of the clutch in the corner, i don't know if they changed it throughout the years but if not that should solve your highbeam issue
Old Mar 23, 2009 | 08:45 PM
Domobomb's Avatar
I Have a '74 firebird, and a '79 camaro highbeams are on the lower left for those years too. You switch it with your foot.
Old Mar 24, 2009 | 02:03 PM
NightWolf's Avatar
oh ok i found it thanks a lot ya its that metal *** on the bottom left lol
pojo1988
Aug 27, 2017 09:35 PM
98Z28ImportSlayer
Mar 16, 2012 09:07 AM
wantvegas
May 17, 2011 12:26 PM
Bing
Sep 20, 2010 08:09 AM
91 RS
Feb 24, 2007 11:14 PM
