67 Camaro Lights Issue
Old May 14, 2011 | 03:03 AM
wantvegas's Avatar
Question 67 Camaro Lights Issue
The lights on this car have never seemed to work right. I have replaced bulbs and looked at the wring the best i could, but i am lost. Please see these 2 videos and tell me what you think it could be. Bulb? Relay? An alien messing with my car? Thank you!!!
The right front turn signal and left back turn signal are the only true working lights.
I have no reverse lights (No wiring for it)
The brake lights only work on the left rear.
The front left signal works, but is very dim, or it runs both front parking lights very dim.
The right rear turn signal does not work.
It says i am running 14 amps in the car, and i am powering my sounds system just fine.
YouTube - 67 Camaro Lights Issue 1
YouTube - 67 Camaro Lights Issue 2
Help please!
Old May 14, 2011 | 07:52 AM
fs68's Avatar
Looks like you are shorting to ground. I would get a meter and wire diagram and trace the wires starting in the trunk. Also make sure all of the wires are hooked up to the right things.
Old May 14, 2011 | 09:21 AM
You have some bad grounds, which will make the power feed try and find other sources to flow through. Your tail light housings are pot metal, and should be grouning to the body. Try a jumper wire from the non-working housing to a good ground and see what happens. Also make sure the sockets are good and clean inside. The front marker lights are grounded through the wiring, so you can again test it with a separate ground wire to the housing or socket.
Old May 16, 2011 | 12:34 AM
wantvegas's Avatar
Sweet! It was just bad grounds! Thank you!!
Old May 17, 2011 | 10:01 AM
StoveBolts's Avatar
As an added note, and I say this cause it took me several weeks to locate and was a source of great anguish for me, but on the front marker lights the ground wire goes from the housing to ground. However, in my case the socket lost continuity with the housing. I resolved this by roughing and then soldering a connection from the housing to the socket.
Old May 17, 2011 | 12:26 PM
That's good 67-68 info to know then. The 69 doesn't have a separate ground wire to the housing, it's part of the harness.
I wasn't positive of the differences, if any, which there is.
pojo1988
Aug 27, 2017 09:35 PM
98Z28ImportSlayer
Mar 16, 2012 09:07 AM
Bing
Sep 20, 2010 08:09 AM
NightWolf
Mar 24, 2009 02:03 PM
91 RS
Feb 24, 2007 11:14 PM
