383 questions!!
There's no difference between the 350 intake and a 383 intake. There is a difference between stock and a good aftermarket. Again, it depends on what cam, pistons, etc. you use to determine if it will run good with a stock. Most all small block Chevys will run better with an aftermarket intake.
I had a 74 Nova with a 383. Had good power and torque. Running a Weiand single plane and 1.94 heads. Blew the thing three weeks after I bought it (I did not do the build it came like that). I found a 350 2bolt block for the right price and just swapped the entire top end over. It was bored .030 and had a double roller. The 2bolt actually made more power with the same parts and was much cheaper. The only thing I do not know was the lift or duration of the cams in either one. Again depends on what parts you have to support the displacement.
