383 questions!!
Old Oct 18, 2011 | 12:41 PM
Specially for $400.
Old Oct 19, 2011 | 11:31 AM
thatcamaro's Avatar
are there any seriel numbers on the heads to look up to see what kind they are?
Old Oct 19, 2011 | 03:44 PM
Yes, remove the valve covers, the numbers are cast on the top of the head: Chevy Small Block Cylinder Head Codes - Chevy Camaro
Old Oct 19, 2011 | 11:32 PM
thatcamaro's Avatar
sorry for all the stupid questions. but how bad would a stock 350 intake choke my 383?
Old Oct 20, 2011 | 09:01 AM
There's no difference between the 350 intake and a 383 intake. There is a difference between stock and a good aftermarket. Again, it depends on what cam, pistons, etc. you use to determine if it will run good with a stock. Most all small block Chevys will run better with an aftermarket intake.
Old Oct 20, 2011 | 03:56 PM
rydeer's Avatar
Did this motor come with the harmonic balancer and the flexplate?
Old Oct 20, 2011 | 11:15 PM
^^^ excellent point^^^
Old Oct 23, 2011 | 10:59 AM
squidnut's Avatar
Default Depends on what you got inside
I had a 74 Nova with a 383. Had good power and torque. Running a Weiand single plane and 1.94 heads. Blew the thing three weeks after I bought it (I did not do the build it came like that). I found a 350 2bolt block for the right price and just swapped the entire top end over. It was bored .030 and had a double roller. The 2bolt actually made more power with the same parts and was much cheaper. The only thing I do not know was the lift or duration of the cams in either one. Again depends on what parts you have to support the displacement.
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
