1980 rear window molding
How the heck to you get the rear window molding off my 80 camaro? i have broke one of those clips trying to pry the molding off. Iam not sure what the clips are held in by! I have really made it look like crap now.
The clips still occasionally break, but new ones are easy to buy. If you break the little studs the clips go on, then you've got a bigger problem! I had a few of those break and I had to drill and tap for 6-32 flathead screws, then epoxy the screws to seal, and install the clips with screws.
Here's the tool:
http://www.handsontools.com/SG-Tool-...GM_p_3990.html
