1979 b/b motor mount swap
Old Oct 11, 2013 | 09:54 PM
jshatek's Avatar
Default 1979 b/b motor mount swap
Please help. I'm putting a 454 in my '79 Z-28. The '72 b/b motor mounts don't seem to line up anywhere on the frame. Do I need to drill new holes in the frame or can I use the stock 350 mounts along with the stock holes? Any help would be appreciated.
Old Oct 12, 2013 | 04:12 AM
HardTOPJoe's Avatar
Yes you can use the stock frame mounts. You might want to go with Polly mounts on the block though instead of the OEM. They hold up better. If you have a/c you may need to modify the box and tall valve covers may cause you clearance issues. with the brake booster.
Old Oct 20, 2013 | 10:37 PM
ArabiaAvonlea's Avatar
These adapter plates will allow you to swap a Chevrolet big block, or small block engine in the place of any 1997-2013 Gen 3 or Gen 4 LS engine.
camaro83
Sep 2, 2012 08:01 AM
kill3rcrack3r
82-92 V6 Tech
Jun 24, 2011 08:09 AM
uestraven
70-81 V8 Tech
Nov 9, 2009 11:06 PM
benz660r
May 11, 2006 09:51 PM
rwtcoburn
82-92 V8 Tech
Jun 24, 2005 06:15 AM
