1970 Cowl Tag Decoding
Old Jul 13, 2009 | 12:45 PM
bbcjimmy's Avatar
Default 1970 Cowl Tag Decoding
Does anyone know what the last series of cowl tag numbers (I believe they are plant codes) stand for? My 1970 Camaro was built in the Van Nuys plant. I believe there are two sets of six digit codes on the bottom center of the cowl tag.
Old Jul 22, 2009 | 12:31 PM
70Z28LT1's Avatar
www.nastyz28.com has extensive cowl tag decoding info
FWIW...my 70 Z does not have the series of numbers you suggest. Mine is a Norwood built car, so I'm guessing yours is a LA Built, and this is referred to as a "DP sequence", for which there appears to be very little info.
Old Jul 23, 2009 | 10:52 AM
bbcjimmy's Avatar
Yep, its a LA built car. Vin sequence shows its number 932 from the plant in 1970. Not a Z - just a standard V8 with Cranberry exterior and black interior.
Thanks for the information.
crxnug
Dec 17, 2013 07:50 AM
lubers
Apr 1, 2012 04:22 PM
bandrew
70-81 Transmission & Differential
Aug 16, 2011 11:51 PM
classact
Aug 10, 2009 08:43 PM
