t 10 decoding
Old Aug 15, 2011 | 05:43 PM
bandrew's Avatar
Default t 10 decoding
i'm trying to figure out if this is the original tranny to my 81 z 28. any help would be greatly appreciated.
3.14.79-1
mlt7802
1304065903
thank you in advance if you can help.
Old Aug 16, 2011 | 11:51 PM
v8chvyguy's Avatar
Borg Warner Second Design ST
3.14.79-1
mlt7802
I would have to guess that these codes are cast in the right lower portion of the case, not stamped? most likely indicating the date and plant the casting was made.
From what I found on my trans, referenced with the site above, there should be a five or six character stamp on the shift fork side just before the midplate section. that is where the date code was on mine.
1304065903 cast the same as the ones above. The last three numbers indicate the type of metal used to cast the case, 902 iron, 903 aluminum, 904 nodular iron.
Also, on the top right corner, mine had the cars VIN stamped into it.
This site also has info for identifying which first gear it has and wide or close ratio.
Doug2000
Mar 20, 2015 07:58 AM
lubers
Apr 1, 2012 04:22 PM
classact
Aug 10, 2009 08:43 PM
Edlanta
70-81 V8 Tech
Jun 12, 2009 09:13 AM
NightWolf
Jan 30, 2007 10:29 PM
