‘79 Coolant temp gauge quit working
Old Jan 3, 2022 | 11:23 AM
MaxDB's Avatar
Default ‘79 Coolant temp gauge quit working
As the title states my ‘79 Coolant temp gauge quit working. I just had the radiator flushed and new coolant so probably a coincidence?
Old coolant was clean and radiator is sludge free.
Is there a way to test the sensor with a DMM?
Thx!
Old Jan 3, 2022 | 07:25 PM
MaxDB's Avatar
I did a little digging on the internet and found some instructions on how to test the Coolant Temp sensor with a DMM. I have copied and pasted the instructions below in case someone else here runs into the same issue. Hoping it's the Coolant Temp sensor and not the Temp gauge!
  • For the testing process you will need to run the engine.
  • Let the engine run to allow the engine to get up to running temperature.
  • While the engine is running you need to be continually checking the digital ohm meter.
  • You are looking for readings that are more than 200 ohms in variance between a cold and warm engine.
  • If you do not see anything that is more than 200 ohms in difference, the coolant temperature sensor is defective and will need to be replaced.
grasshopper645
Jan 27, 2013 03:08 PM
daves86
82-92 V8 Tech
Aug 23, 2012 08:16 AM
josh3408
Mar 8, 2011 08:00 AM
imcdowel
Mar 9, 2010 06:16 PM
g.pelka
Jan 31, 2008 07:00 PM
