tach problem
Old Jan 22, 2014 | 12:53 PM
jeu510's Avatar
Default tach problem
ok, so i have a 383 stroker in my 68 with hei distributor. i have a aftermarket tach hooked up at the tach signal from the distributor. when at idle or sometimes when rev'ed up, the tach will jump. anybody have any idea what it can be?
the distributor is a aluminum billet with new cap and rotor along with new coil, but its not a name brand distributor. possible bad cap and rotor?
Old Jan 22, 2014 | 01:05 PM
The tach gets an ignition signal from the distributor, which in the case of an electronic ignition, comes from the module inside the distributor. A jumpy tach would be either from a bad module, or the tach itself.
Old Jan 22, 2014 | 01:06 PM
jeu510's Avatar
well, tach and module are both new....
Old Jan 22, 2014 | 01:10 PM
Have a clean 12 volt power source to the distributor, and not hooked up to the original resistance coil wire?
Old Jan 27, 2014 | 02:08 AM
jeu510's Avatar
hummm.....now that i need to check and do.....thanks again.
jeu510
Dec 13, 2011 03:55 PM
mgcvd
Sep 29, 2009 12:40 PM
FunkyColdMedina
Jul 23, 2009 12:44 AM
ericlamb
Apr 12, 2007 02:23 PM
z28child
Oct 30, 2006 06:52 PM
