Pull Engine or Not?
Old Aug 3, 2020 | 12:02 PM
jjenos's Avatar
Default Pull Engine or Not?
So my son decided to add aluminum heads on his 67 RS. it's not a numbers match anyway so not a big shock. Engine is a 4-bolt main came from a 72 C10 as far as I can figure from the #'s.
During the process of bolting on the new heads he stripped the front corner head bolt from the engine block. Right next to Cylinder #1.
Should I attempt this on my own, machining skills are medium and I do have all the tools including a 2" block of aluminum to make into a guide block.
Should I just pull engine and bring to machine shop?
Thoughts are appreciated.
Old Aug 3, 2020 | 05:38 PM
Everett#2390's Avatar
Welcome to the club.
I would follow instructions installing a Heli-coil*® and leave engine in place.
Use a min 1/2 inch length coil and pack grease on drill bit and tang remover keeping out as many chips as you can from water jacket.
Old Aug 4, 2020 | 01:33 PM
look for any cracks in or around the hole. its not easy to strip one of these, broken head bolts yes, I would suspect another issue may have added to the problem.
Old Dec 16, 2020 | 02:10 PM
Avispa's Avatar
I don't want to admit how many of those things I put in the deck of my C2 427 block. Never pulled the motor for that, and Everett's advice is spot on. FWIW, I never drilled a deck hole before running the Heli Coil tap.
Just1More
Jul 30, 2018 09:06 PM
Paiste
Feb 19, 2012 08:28 PM
Dcapper81
Dec 6, 2011 03:02 PM
minex
Sep 11, 2011 06:02 PM
94z
Jun 20, 2008 07:49 PM
