iginition recomendations
Old Mar 12, 2011 | 10:07 AM
southw2's Avatar
Default iginition recomendations
I have a 68 396 camaro 4spd and i want to upgrade my iginition system
i was thinking about the MSD 6
What are you thoughts regarding this system pro or cons?
Thanks
ted
Old Mar 12, 2011 | 11:09 AM
If upgrading from points & condenser, even a stock type HEI ignition will make a noticeable improvement in starting and performance. As far as the MSD ignition, I can't say that you'd notice much of a difference if your engine is otherwise "normal". With that said, I have the 6AL model and like it. What's nice about it is the rev limiter function, I put on the adjustable dial module in place of the "pill". Another option (that I still have on the shelf and need to install) is the timing module where you can adjust your degrees +/- on the fly.
Old Mar 13, 2011 | 12:08 AM
southw2's Avatar
thanks for your info.
Ted
fearbunny
Jan 18, 2010 08:42 PM
fearbunny
Jan 18, 2010 07:59 PM
cardana24
Mar 4, 2008 03:07 PM
CAMAROADRUNNER
Jul 14, 2005 12:39 PM
