68 Camaro engine identification
Old Jun 24, 2012 | 10:37 PM
midwest's Avatar
Default 68 Camaro engine identification
The Heads are #3932441 350, 76cc, 161-165cc intake port
The casting is #3932386, which can be the 327 or 350
Suffix code is V0808HV, Which is
HV 1965 327 h/p, hyd lif, t/ig, m/t 350 4Vette
But I also found this on the internet, for the suffix code HV
HV 1969 350 255 4 turbohydro 350
So what do I have?
Old Jun 24, 2012 | 11:41 PM
That's right, it could be either or. Find the casting date on the bellhousing flange, either on the passenger side or towards the middle.
The last digit (5 or 9) will tell you the year, which will then tell you which one you have.
Old Jun 25, 2012 | 06:59 PM
midwest's Avatar
Thanks for that information.
I took a look, and I found H 1 8, which should be August 1, 1968
And I also found the Saginaw clock, which was pointing to the 9th hour of the first shift.
All that, and I'm still unsure exactly what I have.
Old Jun 25, 2012 | 07:03 PM
You have a 1969 350. August 1968 casting would be for an early production 1969 model car.
Old Jun 25, 2012 | 08:09 PM
midwest's Avatar
That's what I was thinking, just really wanted that 350 HP Vette engine
Old Jun 29, 2012 | 07:50 PM
midwest's Avatar
OK, so I find this casting number, 350, on Chevellestuff.com. This one states its a 300hp. So is there any way I really find out what I have?
3932386 1969 350 300 Used from August 1968 until approximately January of 1969 when replaced with 3956618. Used only as 4-bolt block.
Old Jun 30, 2012 | 10:26 AM
The casting number does not tell the h.p. build of the engine, as more than one variant was built off the same block castings. The suffix code (HV) is what tells how the engine was built, which determines the h.p rating. No skating around it, the engine is what the (1969) suffix code says it is.
Old Jun 30, 2012 | 08:15 PM
midwest's Avatar
C69, thanks for the clarification. That's what I was looking for. I appreciate your patience through my investigation.
mrsurfs
67-69 V8 Tech
25
Apr 16, 2012 06:35 PM
cody69
Mar 13, 2009 12:24 AM
uponone929rr
67-69 V8 Tech
Apr 16, 2008 07:53 PM
camaro61
Oct 3, 2007 01:10 AM
