"67" Door Window
Old May 29, 2010 | 09:12 PM
rtadja67's Avatar
Default "67" Door Window
My mounting bracket broke for the drivers side door window. None of the classic car distributers carry anything for the "67". I'm looking for parts, if anyone has any. Also if anyone has a good diagram of how the assembly works and goes together that would help. The diagram in the "Fisher" book is a little vague.
Old May 29, 2010 | 11:02 PM
Squid's Avatar
got a welder?
Old May 30, 2010 | 10:15 AM
rtadja67's Avatar
Default Door window mounting bracket
I was able to weld the bracket luckily, and it mounted to the glass great, but something is wrong. When I put it all back together, the way it came out, the window seems loose in the channel. I put the forward bracket into the vent window channel and adjusted it real close. It may not be perfect but rolls up and down real good. The only thing is when I grab the window it will move (or should I say pivot) kinda like the forward bracket isn't attached. On "68-69" models both door window brackets (forward + rear) are attached to the glass, on the "67" the forward bracket slips into the vent window channel. HELP.
AmericanMuscle1989
Jun 25, 2013 10:38 AM
tonyfronce
Jul 10, 2012 10:33 AM
nebchevy
Sep 15, 2011 09:26 AM
Mesosneaky
Sep 2, 2011 07:35 PM
