rtadja67 |
05-30-2010 10:15 AM |
Door window mounting bracket
I was able to weld the bracket luckily, and it mounted to the glass great, but something is wrong. When I put it all back together, the way it came out, the window seems loose in the channel. I put the forward bracket into the vent window channel and adjusted it real close. It may not be perfect but rolls up and down real good. The only thing is when I grab the window it will move (or should I say pivot) kinda like the forward bracket isn't attached. On "68-69" models both door window brackets (forward + rear) are attached to the glass, on the "67" the forward bracket slips into the vent window channel. :icon_doh: HELP.
