1969 L78 Engine Block Rebuild - Value Question
Old Mar 20, 2018 | 12:48 PM
Hammer1971's Avatar
Question 1969 L78 Engine Block Rebuild - Value Question
All: I have a 1969 Camaro with a L-78 Big Block 396 that needs a rebuild. My question for the group is - do I get more overall car value from keeping the original steel cast cylinder heads - or would it hurt or improve value if I jumped to the winters (or other) aluminum cylinder heads (more HP - fun to drive, lighter, etc.). Unsure which direction to go here - could use some advice.
Old Mar 20, 2018 | 01:49 PM
Al Loyrat's Avatar
I say go aluminum but keep the iron heads (don't sell). Winters casting are probably pretty pricey and need to be inspected very carefully. Are you staying stock compression and solid lifter? The nice thing about going aluminum heads is they are more pump gas friendly with high compression. Also takes about 75 lbs off the front end.
Old Apr 7, 2018 | 05:08 PM
Al Loyrat's Avatar
(crickets chirping)
Old Apr 8, 2018 | 12:37 PM
Y2K's Avatar
Y2K
Talking
(crickets chirping)
For what it's worth I agree 100%.
danc
Aug 26, 2010 10:28 PM
danc
Jun 16, 2010 10:29 AM
Papabone
Nov 12, 2009 08:22 AM
RS/SS X66
Sep 16, 2009 08:47 AM
