Traction Bar for 67
Old Jul 20, 2019 | 06:22 PM
FrazerRS's Avatar
Default Traction Bar for 67
I have a 67 RS that was built before they added the traction bar. I do not have the plate on the floor pan as well. I would like some recommendations for adding a traction bar and what type. I would also like to convert my 10 bolt to a limited-slip so I do not have a one wheel wonder. I have already converted from mono leaf to a multi-leaf spring. I realize that Chevy was adding the single torque bar after the fact for early run Camaro's. This car is not numbers matching and now has a 350 with a Turbo 350 transmission. Originally it was a 327 with a power glide so I am not worried about keeping it original.
Old Jul 21, 2019 | 10:27 AM
Zspoiler's Avatar
You can always use CalTrack bars besides lakewoods are another
Old Jul 21, 2019 | 10:41 AM
FrazerRS's Avatar
I was looking at the CalTack bars. I was wondering if anyone had experience with them. if anyone has a picture of the CalTrack bars installed on their car I would like to see what they look like as well. Thanks Everyone for your help.
Old Jul 21, 2019 | 11:44 AM
Old Jul 21, 2019 | 11:55 AM
If you're not going after originality, then aftermarket traction bars will do the trick. The clamp on bars like Y2K listed will work, and are easy to install. But since their design by nature puts stress on the springs compared to the type that is integrated with the lower spring plate, they're not nearly as good as other options. All depends on how many horsies your engine is putting out, and how much you plan on beating on it.
Old Jul 21, 2019 | 12:59 PM
FrazerRS's Avatar
Deffinitly is not original at this point. Thanks for the help I am going to google some installed ones to see what they look like. Only enough ponies to light them up for fun.
Thanks again.
Old Jul 21, 2019 | 01:36 PM
Exactly,took that into account considering a 350/350TH in his car,low cost and easy install.
Heck I ran that style with a 427 4 speed in my old '69 and they worked just fine with multileafs.
Old Jul 21, 2019 | 03:08 PM
FrazerRS's Avatar
Thanks Road Tripper
Old Jul 22, 2019 | 11:15 AM
Old Oct 11, 2019 | 09:01 PM
dbs1's Avatar
I used caltracs on my former BBC 67 making 650 on the engine, 150 shot of nitrous and running 9.9 in the qtr. Coupled with a 3.73 12 bolt with posi and 12.5" slicks it would hook and book with 1.4 short times. They work!!!
camie
Jul 21, 2019 11:07 AM
gmshadow
Jun 23, 2018 04:56 PM
wantvegas
May 23, 2011 03:54 AM
dusty
Aug 17, 2006 12:21 PM
bowtieguy
Apr 26, 2006 11:09 PM
