Rear Axle
Old Oct 9, 2020 | 01:36 PM
Eric Sabatier's Avatar
Default Rear Axle
I am opening a new thread for the rear axle on my 68.
I have several concerns with it.
It's a10 bolts single leaf with 3 leaves.
Marked 3894859NF and CM57
I can't open the square fill plug
The teeths seems to rattle a bit
Transmission shaft had about 1" of play when everything was on the car (when turning the shaft it was moving by about 3/4-1")
I will have to have it checked locally to estimate it's real condition.
I would like to refinish it but it's muddy, greasy and am not sure how I can degrease it so I can paint it...
So a lot of work to still have a 10 bolt at the end of the day(s)
I saw this page https://www.moserengineering.com/12-...d-package.item
About 2.000$
Anyone would like to dig into that and tell me what option I'd need. I'd appreciate.
What value will a 12 bolts add to the car?
Old Oct 9, 2020 | 07:40 PM
Transmission shaft? I think you mean driveshaft,the long shaft with u-joints between the trans and the rear end.
If that's the case that much movement is fairly normal with the trans out of gear.
Old Oct 9, 2020 | 07:46 PM
Old Oct 10, 2020 | 01:49 PM
Sorry yes driveshaft. It has this kind of movement when it was in the car and the car on its wheels.
Old Oct 11, 2020 | 12:10 AM
MKCoconuts's Avatar
Just an FYI, not all 10 bolts are the same. GM had a 7.5/7.6, 8.2, and 8.5/8.6 10 bolt. You more than likely have the 8.5 and it's a very strong axle even stock. Built, it can handle what a 12 bolt can.
Old Oct 12, 2020 | 03:56 PM
You're correct, it's well a 8.5" on the car. I am not that much concerned with the fact that it's a 10 bolts, I could live with it easily.
No the problem is the amount of work required and that it's originally a single leaf axle.
I am considering having a new one installed but there is a lot of options ! So again if anyone can help with th link I provided on the first message, I would appreciate;
Then I would probably need a new set of leaf springs. But which one. 4 or 5 leaf, what style? I see that some are sold as "improved handling". What do I need?
Old Oct 26, 2020 | 02:25 PM
My car has a single leaf rear axle but installed is a 3 leaf spring.
Am I correct in assuming that we can use 3 leaf springs on single leaf axles (with spacers) and that a multi leaf axle will use 5 leaf springs?
Old Oct 26, 2020 | 03:04 PM
Everett#2390's Avatar
Those 3-leaf springs are probably the JC Whitney replacements made by Eaton Spring as they did away with the rubber pads installed on the OE mono-leaf/perch design.
Old Oct 27, 2020 | 07:48 AM
Zspoiler's Avatar
the 68`s came with an 8.2 rear end of which are weak .You can replace it with an 8.5 10 bolt from a 1973-4 Nova .And or a 12 bolt from a 1968-71 Nova and or 1967-9 Camaro .Original and or aftermarket.I have used the original 8.5 10 bolt housing rebuilt with upgrades behind a 500 HP small block/Super T-10 for years with no issues,
Old Oct 27, 2020 | 11:49 AM
Everett
you mentionned before JC Whitney on my "Rear Leaf Pads" thread.
You said then "I believe no pads required with three-leaf springs. I could be mistaken."
I don't think that no pads as I never saw in my very limited experience rear leaf springs with no pads.
In any case Eckler's sell a conversion mono to multi leaf but I am not sure if you use it on a mono leaf axle with 3 springs or with 5 springs.
In any case it comes with a plate that would allow the use of multi leaf pads (with centering stud) in a multi leaf perch (with no hole in the middle)
Part #: 33-212620-1
Camaro Leaf Spring Conversion Kit, Mono To Multi, Detroit Speed, 1967-1969
Zspoiler, I have well a 8.5-10 bolts axle. I am not sure if I keep it, restore it or order a Moser engineering 12 bolts.
