New here & seeking flywheel recommendation
Old Aug 5, 2017 | 11:56 AM
Mikedril's Avatar
Default New here & seeking flywheel recommendation
Hello all. I had small block Camaro's ,in the past, and now have a '68 with a 396. It's got 3.42:1 rear gears and 10 spline input shaft on a M22 Rock Crusher. The stock clutch is on it's way out and I plan to replace it with a McLeod twin disc 6911-04.
For street driving, with an occasional trip to the strip, would I be better of with a lighter weight aluminum flywheel, or should I just resurface the existing flywheel?
Thanks in advance for your opinions.
Mike
Old Aug 5, 2017 | 08:15 PM
Everett#2390's Avatar
Welcome to the Club, Mike.
IMO, I would stick with steel flywheel.
Alum design is generally for an engine running at 4K and above.
You have a BBC, meaning stroke, M22 and 3.42:1 gear for moving the mass.
I believe you're not going to gain much with alum.
But, others opinions may differ. We shall see, er, read.
DiamondBlue559
Dec 14, 2010 11:31 PM
Extreme Dimensions
Dec 9, 2009 01:12 PM
Mezzio
May 7, 2009 10:29 PM
karlisdad2005
Feb 21, 2008 10:43 PM
ddeaton66
May 31, 2006 02:38 AM
