Muncie 4 Speed Tranny Fluid?
Old Jul 19, 2011 | 06:17 PM
fastb's Avatar
Default Muncie 4 Speed Tranny Fluid?
My camaro has a Muncie 4 speed and was curious if I should use 90 weight gear lube or an ATF like you would in a modern manual transmission? Old man at O'Reilly's told me to get the gear lube so I did, but want to check with you guys on this also.
Old Jul 19, 2011 | 06:33 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
I run a straight 90 weight in my T-10.
Old Jul 19, 2011 | 08:57 PM
v8chvyguy's Avatar
It specifies 80w90. ATF dose not work in the old gear boxes.
Old Jul 19, 2011 | 09:00 PM
fastb's Avatar
ok guys all I needed to hear, thanks for confirming
Greg69RS
Aug 15, 2012 07:34 PM
67SuperSport
Mar 6, 2011 12:37 AM
Carkid70
70-81 Transmission & Differential
Oct 18, 2010 03:03 PM
AAMCO4720
Nov 22, 2006 09:53 PM
TimmyTheWop89
Dec 3, 2005 11:55 AM
