M41 trans code
Old May 4, 2012 | 09:40 AM
motoreyes's Avatar
Default M41 trans code
On my 67 Camaro built in LOS, on cowl tag it has M41 as trans. My search showed only M11, M20, M21, M35, M40 as choices. Anyone know which it came with? It no longer has orig motor or trans, just curious.
Old May 4, 2012 | 11:16 AM
Can you show a picture of your trim tag? For an LOS car, The "M" code (if we're talking about the same one) should be referring to a TH400 automatic trans.
Old May 4, 2012 | 02:36 PM
motoreyes's Avatar
Default cowl tag pic
Here is the pic.
Old May 4, 2012 | 03:05 PM
Old May 4, 2012 | 03:28 PM
motoreyes's Avatar
Thanks, that explains it.
Old May 4, 2012 | 03:46 PM
There's also some speculation that the "M" code where it shows powerglide trans on the breakdown, might only apply to NOR built cars, and for LOS cars it may mean a TH400. You can do some more research if what yours had is questionable, or if you even care.
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
1995Camaro
Jan 11, 2009 07:53 AM
1994z28
Dec 19, 2007 07:17 PM
WULFFTRUBLE
Nov 10, 2006 09:07 PM
