Gear Ratio
Old Oct 30, 2022 | 12:38 PM
LarryD's Avatar
Default Gear Ratio
DISREGARD, I just found the thread on this... Sorry for the needless post....
67 Stock SS 350 with Muncie 4 speed and 12 bolt posi. What is the best all-around differential gear ratio for car? The restoration is to stock and will be a trailer queen with occasional road trips. Looking for reasonable power without killing gas mileage terribly.
Thanks..
Old Oct 31, 2022 | 07:25 AM
Gear selection is about what you want or even the terrain were you live. When I lived in South Carolina even thing was flat and wide open. In West Virginia finding and strait roar other then an interstate was tuff.
I like the stock 3:55. Just keep in mind that tire diameter had as much effect as rear gear. If you know the diameter and can calculate a final drive. Even car has a 1:1 ratio gear (non-overdrive) So you could test cars and find on you like then get the same final drive. This would verify your cruising speed and top end limits.
Old Nov 9, 2022 | 09:11 AM
LarryD's Avatar
Thanks. I finally opened up the differential and it is currently a 3.31. The gears look good and as near as I can tell so does the backlash. The pinion seal needs to be replaced so I think I will just replace that and the axle wheel bearings for now. Budget constraints...
WayneJackson
Apr 14, 2021 07:55 PM
shippy8907
Feb 14, 2009 10:45 AM
nlubrano
Jan 3, 2009 02:59 PM
bowtie70350
LS Series Tech
11
Apr 21, 2007 12:01 AM
blink18236dude
Jan 4, 2007 12:27 AM
